Community License
The Community License is free and require no registration.
It allows you to use the data from every sensors of the Pioupiou Wind Network, for any use − including commercial use −, as long as you comply with the following rules :
Attribution
You must give credit and provide a link to the http://pioupiou.fr website in a visible part of your application.
Example : Wind data © contributors of the Pioupiou wind network http://pioupiou.fr
You may do so in any reasonable manner, but not in any way that suggests that we endorses you or your use.
You must not claim that you are the owner of the original data.
Sharing
If your application integrates data from other weather sensors, the data from those other weather sensors must be open, according to the following definition.
If your application integrates data from other weather sensors, and if the data from those other weather sensors is not open according to the following definition, then you are not allowed to use Pioupiou Wind Data under the Community License. In this case, you may contact us for an Extended License.
Definition of open data :
“An open data is a data that we can use exactly the same way as you.”
The data must be available on a public website or on a public API.
The data must be available at no cost.
The data must allow reuse by anybody, for any application (including commercial application and redistribution).
The data must be in a computer-readable format.
The data resolution must not be degraded. You must provide the same dataset as the one you use.
The data update must not be delayed.
If your application uses archive data, you must provide a way to retrieve the full archive.
We reserve the right to add more terms to this definition in case we face any abuse.
Service Level
We make our best to keep the system up and fast-responding. However the Community License does not provide any contractual warranty about availability and maintenance of our services.
If you need a Service Level Agrement, please apply for an Extended License.
Warranty
Our data is provided “AS IS”, with no express or implied warranties of any kind, including, but not limited to, any implied warranties of merchantability or fitness for any particular purpose or warranties against infringement of any proprietary rights of a third party.
We will not be liable for any consequential, incidental, or special damages, or any other relief, or for any claim by any third party, arising from your use of this material.
