DIGIFLY et MAC, peut etre un espoir
J’ai échangé quelques mails cette semaine avec un gars de chez Digifly, qui m’a dit que désormais a marchait avec les MACs. Plus besoin d’avoir un PC ou pire, d’installer windows sur son mac…
Je vais donc enfin pouvoir utiliser mon Leonardo pro sur mon mac, pour avoir mes traces et W/P.
Voila un copié collé des mails qu’il m’a envoyé, en indiquant la procédure:
Bon vols à tous
Benoit
MAIL 1:
have many customers with Mac and they are able to manage to LeonardoPro.
Here are some useful notes :
  • download and upgrade on your Digifly instrument the latest firmware that you find at this link :
    www.digifly.com/downloads/firmware/Upgrade_64_3_Leonardo_Pro.zip
    VERY IMPORTANT : when you upgrade the instrument with a new firmware all setup parameters and all your flights will be deleted.
  • thanks to Stein Sorensen we can up/download waypoints and download flights of the Digifly Leonardo Pro also on a Apple MAC.
    Also saving the flights as .kml or .gpx or .igc is possible. I tested the functions and it works fine now.
    here’s the link for this tool: http://www.multinett.no/~stein.sorensen/body_mac.htm
  • be sure to install the latest USB cable driver for Mac that you find on our web site .
RS232 CABLE
real COM works much better then USB cable.
  • be sure the wiring has still good connections.
USB CABLE
in case of USB please follow these notes :
  1. unplug the Usb cable
  2. install latest driver from this link http://www.digifly.com/downloads/other/DIGIFLY_NEXTGEN_USB_Driver.zip
    (the Digifly USB adapter is based on the Prolific PL-2303 chip)
  3. connect the USB cable to the PC
  4. on your PC for best compatibility with almost software reassign the “Prolific” COM port to COM5 and remove all unused COM ports.
    (most programs do not like COM port with higher number).
    How to do it :
  • go to the Device Manager (Windows Xp > Start / Control Panel / System / Hardware / Device Manager or Windows Vista > Start / right-click on Computer / Manage / Device Manager)
  • click on the plus (+) sign next to “Ports” , if the device in installed properly you will see “Prolific Usb-to-Serial Com Port (COMx)”
    where “x” is the com port assigned to the cable.
  • right click on the “Prolific Usb-to-Serial Com Port (COMx)” and then click on Properties
  • click on Port Settings / Advanced and from the pull down menu select COM5
  • reboot PC
ERROR RETRY LIMIT -5 PROBLEM
  • be sure to use the correct program upgrade for your vario model
  • be sure to do NOT run the program from a zipped archive , always unzip it on your hard drive.
  • be sure to do NOT run the program from a removable disk, always run from your hard drive.
PROTOCOLS
The Leonardo “talks” two different protocol languages : the MLR protocol and the Digifly protocol.
MLR PROTOCOL
The MLR protocol is used to communicate directly with CompeGps , GpsDump and Maxpunkte , with these programs you can downloads any flight you want from the Leonardo logbook (in this menu move the cursor to highlight the flight you want).
The “G” record is automatically generated by these programs so the file is ready to be sent trough the web to the online contest server.
With CompeGps and GpsDump is also possible to upload the competition waypoint list to the Leonardo , for this function you need to position the cursor of the Leonardo on the “WPT COMP” menu ( do not enter in it).
To communicate with these programs (CompeGps , GpsDump and Maxpunkte) you need to select on the PC the MLR protocol and the COM port.
DIGIFLY PROTOCOL
The Digifly protocol is used to communicate with the software DigiflyVltools2009v2.2 (download it from this link http://www.digifly.com/downloads/other/Vltools2009v22.zip ) and the software DigiflyVltoolsConfigurator_10301 (download it from this link http://www.digifly.com/downloads/other/VltoolsConfigurator.zip )
To communicate with these two Digifly programs you need to enter in the “vltools” menu on the Leonardo vario ( you’ll see a blinking text “link”) .
The DigiflyVltools2009v2.2 is used for upload/download waypoint and routes. Flights downloaded with this software do NOT contains the “G” record.
The DigiflyVltoolsConfigurator_10301 is used to download the last flight from the Leonardo and it adds automatically the “G” record .
Almost online contests have already received our vali-xdg.exe ( http://www.digifly.com/downloads/other/vali-xdg.zip ) to validate our Digifly digital signature (g record).
It’s very useful also to configure the whole Leonardo including page settings and custom acoustic settings.
MAIL 2
he driver from this link http://www.digifly.com/downloads/other/DIGIFLY_NEXTGEN_USB_Driver.zip
includes also MAC drivers.
On your MAC for best compatibility with almost software reassign the “Prolific” COM port to COM5 and remove all unused COM ports.
I confirm you that all works fine with MAC
Whaouuu! Génial, on peut décharger son GPS sur un Mac. Tain chez Apple c’est quand même des pionniers, j’ai du mal à imaginer tout ce qu’on va pouvoir faire d’une pareille innovation…
Barbulle? à toi!
:wink:
euh… pas la faute au mac, mais au éditeurs des softs qui pensent qu’à windows…
Peut-être mais le résultat est le même…
Tu prends n’importe quel PC récupéré au fond d’une poubelle ou d’un débarras et tu décharges ton GPS tranquille…
Avec un Mac payé la peau des fesses tu galères…
l’histoire ne dis pas si l’upgrade est possible en mac ou s’il faut faire appel à un ami :grat:
:stuck_out_tongue:
:+1: y compris avec nux. bien sur il existe de(s ?) programme(s ?) pour récupérer les traces la somme de tous les points par où est passé le GPS … mais pas aussi simple que les logiciels sous windows … déjà je trouvais dumpGPs à la limite de la barbarie de devoir mettre les doigts à l’intérieur de dedans les points pour les télécharger :?
le pire étant les tomtom et autres joujous (nokia par exemple)
Hey les gars, détendez vous et allez voler un peu plutôt que de relancer le débat mac/pc , qui est un débat sans fin, meme si tout le monde sait que les macs ont raison. :wink:
Bizzzz
t’as oublié un ‘r’ à maRc. Les Marcs ont raison :stuck_out_tongue:
Ben le jour on vole et le soir on raconte des conneries…
elle est pas belle la vie?
:wink:
BON,
Voila ca marche enfin chez moi , sur mon mac.
J’ai du changé mon cable, car il était défectueux. Depuis ca marche nickel sur le mac, pas besoin de windaub.
Procedure:
1 installer les drivers MAC que l’on trouve sur le site de digifly
2 installer GPSDUMP, derniere version
3 brancher le cable
4 allumer le vario et le connecter
5 lancer GPSDUMP
6 IMPORTANT: dans le vario, aller dans la page LOGBOOK, et mettre en surbrillance (en noir), la ligne du vol que l’on veut telecharger
7 dans GPSDUMP, cliquer sur MLR/DIGIFLY
VOILA :slight_smile:
Si ca ne marche pas: changer les parametres de GPSDUMP dans MISC/SET COM etc .
enjoy :slight_smile:
Ok merci Boeing737 pour la procédure.
(Post envoyé d’un mac :stuck_out_tongue: )
Ouais ben ça marche quand même pas :frowning:
(post aussi envoyé d’un mac :stuck_out_tongue: )
