Expedition. SkyMax Paramotors.
Anodized aluminum frame started as prototype, during development we changed the type of aluminum and design to improve weight, ease of assembly in the field and rigidity, we are now able to make frame customizable and basically we can put any engine on the frame. Cage hoop is made of titanium(as well as the s-bars) rigid, light and easy to assemble. Beams and struts are made of carbon fiber and we chose this material not only because of weight and rigidity, but because of practicality(in case of unlikely event of breaking of one of the beams it is easy to swap/replace them in the field). Mesh material – hand woven dyneema. All of the connectors serve double purpose for ease of assembly and weight reduction. SkyMax Fuel tank – It is a soft tank weighting 0.45kg(1lb)(comes with fuel pump, fuel system piping for you ease).
Assembly weight 18kg with EOS Booster(60kg of thrust) and 21kg when paring with Moster 185(75kg of thrust). Suspension Skymax weighing only 2 kg! Skymax Expedition – is designed for travel!
Frame weight 4kg/8,8lb, Frame weight with tank 4,5kg/9,9lb
What’s in the box:
Anodized aluminum Frame/Chassis.
Titanium S-Bars.
Titanium Cage Hoop.
Carbon Fiber beams and struts.
Hand woven dyneema Mesh
Helix 1250 carbon prop.
Moster 185 engine(customizable).
Soft Fuel Tank
Fuel pump
Fuel system piping/tubing
Carbon fiber repair kit(3 spare carbon fiber beams)
Protective luggage for the whole paramotor with slots for props.
Instruction.
All brand new.
3650 Eur
We offer 10% discount on the chassis/frame until the end of June.
Delivery is not included, but we can and we will arrange everything for you(delivery to your door, with no import taxes/if needed).
Email: info@skymaxavia.ru
https://www.facebook.com/SkyMaxParamotors/
https://www.youtube.com/channel/UC8QdKvhE4ArEB6kztoyH-xA
