Oui exact.
Idem pour le Brauniger IQ One et IQ One+ qui sont des appareils très similaire au Flytec 6005 et 6010 je pense (pour pas dire les même).
J’avais contacté Brauniger et voici ci dessous l’explicatif qu’ils m’avaient donné.
Depuis çà marche a merveille.
[quote]Hello,
Begin of this year 2007 I bought my new IQ One+ variometer and I experience since some strange flight records with it.
The variometer did record extra high “max raise” figures on 4 fligths out of the 15.
Flight 60 : Max Raise = +16,9 m/s On graph max raise = ca +2 m/s
Flight 54 : Max Raise = +16,0 m/s On graph max raise = ca +0,2 m/s
Flight 51 : Max Raise = +15,2 m/s On graph max raise = ca +1,3 m/s
Could you help me to solve this problem?
Do you think it is a setting problem?
Or is there something wrong with the hardware of the IQ One+ and have to return to Brauniger?
Best Regards.
Pierrot.
[quote]Hello Norbert,
Thanks for the “workaround” tip.
This sounds like a bug in the software of the IQ One+.
Is there any upgrade of the firmware planned/possible?
Regards.
Pierrot.
[quote]Hello Pierrot,
mostly the “bug” will not be present as a pilot normally should correct his heigt at the starting place. But it’s a weak point and we will correct this at a later version of the IQ-ONE series. As the software is a OTP type it can’t be flashed by a new program. OTP controllers are extreme safe but can’t be updated.
So please do the correct starting procedure to get correct flight values.
Best regards
Pierrot.
