thermocompass
quelqu’un connait ca ?
http://thermocompass.nethouse.me/ :koi:
J’ai lu la FAQ. Maintenant je cherche la FAQ de la FAQ. :expressionless:
Je viens de tomber dessus par hazard moi aussi
il y a plusieurs vidéos intéressantes qui tendraient a démontrer l’efficacité du bazar
http://www.youtube.com/watch?v=I9OD8dYRYz0&feature=relmfu
et
http://www.youtube.com/watch?v=_dNtc5_CNHM&feature=youtu.be
il faudrait que REVERSALE intègre ce logiciel sur le VPG :dent:
preFlightEditor
http://www.youtube.com/watch?v=bMXlyYzkOaE
:dent: http://xxcb.blogspot.com/2013/02/aplicativos-para-voo-futuro-ou-presente.html
New update Thermocompass software. Since version 3.0, the validation key of its IGC logs are accepting by http://vali.xccomp.org/vali-verbose.html , GPSDump software and so on…
LK8000 and Thermocompass simultaneously in the same device. This technology is implemented in the new 4.0 TC version. The development is intended primarily for competition.
http://paraplan.ru/forum/files/2794/980744907.jpg
Friends! New TC v4.6 is available!
We have updated 80% of the program with your comments and suggestions. Special thanks to the most active pilots/testers:
Niknik, Habl, WashGen, Kels, Jumbo Jet, mzeddd, BadMad, Marcial Campos(Spain), Wanderlei Goncalves de Souza Junior
(Brazil), Konstantin Karcin (Lithuania), Gurka (Andorra).
That is new:
  1. Most of screens are updated to be more readable on the sun. With white screen and black/dark info items (arrows,
digits, etc.)
Examples:
http://paraplan.ru/forum/files/2794/516039563.jpg
http://paraplan.ru/forum/files/2794/1463538641.jpg
http://paraplan.ru/forum/files/2794/883738592.jpg
http://paraplan.ru/forum/files/2794/136737930.jpg
http://paraplan.ru/forum/files/2794/1214552798.jpg
http://paraplan.ru/forum/files/2794/1704899353.jpg
  1. On the first screen (horizont level indicator) you can get accumulated information about thermal activity for the last
10-15 seconds around the pilot. It might be helpful in very turbulent air conditions
  1. New!!! You could configure your screens with info indicators you like. There are four indicators on the screen that
you could tune by pressing on it. There are 14 indicators in total:
“Course”
“Speed, km/h” - Horisontal speed from GPS.
“Vario, m/sec” - Vertival speed from GPS. Averaged with 1 second
“Vario 10s, m/s” - Vertival speed from GPS. Averaged with 10 seconds
“Altitude, m” - Altitude from GPS
“Wind , m/s” - Calculated wind speed
“Wind dir” - Calculated wind direction
“Glide Ratio”
“Thermals level”
“Detector”
“Timer” - Flight time
“Time” - Current time
“FPS”
“Free memory”
“Sat used” - Number of used GPS satelites
All this info indicators are valid for most of screens (except map screens).
You need to configure indicators only once and then TC will remember them
  1. Screen #2 has the same behaviour. Just colour scheme is different.
  2. Screen #4 has new colour scheme and bigger size of info items to get it more readable
  3. Screen #5 - no changes
  4. Screen #6 (Vario) is much simpler now. Plus it has TC arrow from now.
  5. Screen #7 (Coloured track tail) - no changes
  6. New!!! From v4.6 program uses two different algorithms for weak and normal thermal conditions. Depending on "Thermals
level" value in “Setup” menu TC chooses which algorith to use. If this value is less than 0.42 then slow and precise
algorithm is used. This algorithm is good for weak conditions with smooth and wide turns without agressive piloting
http://paraplan.ru/forum/files/2794/1733240691.jpg
  1. Fixed problem with west longtitude
  2. Important! From now in case of joint usage of TC and LK8000 you have to switch between programs manually. To be able
to do this you have to press (and hold for 2 seconds) on the area where battery indicator is located on face side of
Funtrek.
PS: This version of TC is dedicated to Konstantin Karcin who helped a lot in TC improvements. He died one month ago
during the towing winch because of heart attack.
