Ziad vient de publier son avis sur l’Explorer :
[i] After the Carrera plus , here’s GIN new light B glider with an aspect ratio of 6.1
Take off is super easy as the glider inflates quickly with no overshooting.
Flying the Explorer S (75-95) at 94 all up with an X-rated 6 harness.
The brake pressure are similar to the C+ ones ,and the explorer can be steered with only 10 cm of brakes travel in moderate thermals. The response is shorter than the C+ with (more or less) same agility. And with much more brake dampened behavior.(less sharp)
The thermals are felt by the risers. Nothing comes through the brakes . The Explorer feels like a solid ,dampened ,comfortable to fly mid B glider. I know that the AR is 6.1 but it doesn’t feel at all …
Flying next to a loaded Rook 2 seems to show a slight 0.5 km/h faster trim for the Explorer with probably a very slight edge in glide performance at trim. At full bar the Explorer S at 94 all up, has around 8- 9 km/h speed over trim taken at 1500 ASL. The glide at full bar seems close to the Rook 2 with also a slight edge…
Another example, is that flying a Chili 4 with it’s edge in overall performance, feels more demanding to fly than the Explorer in turbulent conditions.
The overall performance of the Explorer is quite nice for an easy B glider. The Carrera plus overall performance is slightly higher but with more pilot workout. The Explorer felt much easier, safer, and more comfortable. Flying the Explorer at full speed is very usable. I have tried to pull 10 cm one A riser at full speed and the Explorer leading edge didn’t collapse. So the margin at full speed is fully usable even in turbulence, with the ability to steer the glider efficiently while on bar, with the C risers in moderate turbulence.
Big ears are very efficient, stable. They reopen by a slight brake amount.
Conclusion: Let’s keep the original Carrera and the Carrera plus, aside. Their glide performance and especially their climb rate is ‘legendary’ !
The explorer could be the most easy to fly 6.1 aspect ratio B glider ! The overall performance are very good for the category, but not comparable with it’s bigger sisters. In my humble opinion, i believe that the Explorer is aimed for a wider variety of B pilots and i think any B pilot coming to the mid, high B category will be welcomed on the Explorer.
A light, quite maneuverable, easy to fly and to pack, a ‘cool’ companion for adventure flying with good overall performance. That’s the Explorer ! [/i]
